Mine was intermittent. The alert came on and sometimes go off. Next day the car started a journey with no alert then perhaps come on after 5 mins of driving.Thanks for that , l will get it checked , noticed seat belt tensioners not working , so will check fuses ,
My next service will be at MB specialist non franchise family business, so sure they will sort at reasonable price
I have never noticed this at all. What model year is your MP? In my limited experience such tensioners pre fire in advance of a collision only. This to limit any force impact on your torso.The seat belt tensioners are the ones that tighten a little when ignition is put on .
Feature | What it does | Whether it’s standard / optional in 2019 Marco Polo |
Collision Prevention Assist | Warns the driver if a collision risk is detected ahead, gives warnings; may assist braking. | Optional, often part of “Driving Assistance†package. |
Adaptive Brake Assist / BAS PRO | A more advanced brake assist that can increase braking if driver reacts late, etc. | Optional. |
Active Distance Assist (DISTRONIC) | Keeps a safe distance from vehicle ahead (adaptive cruise function) in traffic or highway. | Optional on many trims; part of driver assistance packages. |
Lane Keeping Assist | Warns if drifting out of lane / helps prevent unintended lane departure. | Optional. Possibly standard on higher-spec / with certain packages. |
Blind Spot Assist | Alerts driver to vehicles in blind spots when changing lanes. | Optional. |
ATTENTION ASSIST | Monitors driver behaviour (via steering, etc.) for signs of fatigue or reduced attention; gives warning. | Standard or frequently included. |
Crosswind Assist | Helps with vehicle stability during strong side winds. | Standard in many markets for Marco Polo. |
Highbeam / Headlamp Assist | Automatically adjust headlamps (dipping / bright) to avoid dazzling others. |
What model year do you have carol?Thank you , never seen this list before ,l believe l originally set up the seat belt tensioners using the centre touch pad , it always slightly tightened on switching on ignition, l will do a search for fuses , will also disconnect seat belt when in motion to see if warning comes on
