Pre safety features not working. Dashboard warning
Carol
I returned from hols , 2000miles 3 weeks ago , then went out to start my van and would not turn , put battery on charge using points under bonnet , after 2 days all started and running , but l get pre safety features not working, Has anyone else experienced this
Yes. It was an abs sensor fault on one wheel. Cost about £160 to fix at an independent. Common fault loads have had it.
Thanks for that , l will get it checked , noticed seat belt tensioners not working , so will check fuses ,
My next service will be at MB specialist non franchise family business, so sure they will sort at reasonable price
Mine was intermittent. The alert came on and sometimes go off. Next day the car started a journey with no alert then perhaps come on after 5 mins of driving.
If you have access to a diagnostic monitor of some sort it’ll be apparent. Not a big issue they do age over time and degrade.
The seat belt tensioners are the ones that tighten a little when ignition is put on .
I have never noticed this at all. What model year is your MP? In my limited experience such tensioners pre fire in advance of a collision only. This to limit any force impact on your torso.
The Mercedes pre safety functions are in the 2019 Mp outlined below (probably no exhaustive) but if various conditions are not met then you get the pre safe functions limited. It could be another issue you are experiencing but we have had a few of these posts recently and it was an abs wheel sensor that was the root of it.
  • Detects critical driving situations (for example an imminent collision) using sensors and warning systems.
  • Automatically initiates precautionary occupant protection measures, such as tightening front seat belts (pre-tensioners) to restrain occupants more firmly.
  • Possibly closes windows / sunroof or moves parts to reduce injury risk (if fitted). While I didn’t find in every spec sheet that this is guaranteed, this kind of action is standard in many Mercedes PRE-SAFE systems.
FeatureWhat it doesWhether it’s standard / optional in 2019 Marco Polo
Collision Prevention AssistWarns the driver if a collision risk is detected ahead, gives warnings; may assist braking.Optional, often part of “Driving Assistance†package.Â
Adaptive Brake Assist / BAS PROA more advanced brake assist that can increase braking if driver reacts late, etc.Optional.
Active Distance Assist (DISTRONIC)Keeps a safe distance from vehicle ahead (adaptive cruise function) in traffic or highway.Optional on many trims; part of driver assistance packages.
Lane Keeping AssistWarns if drifting out of lane / helps prevent unintended lane departure.Optional. Possibly standard on higher-spec / with certain packages.
Blind Spot AssistAlerts driver to vehicles in blind spots when changing lanes.Optional.
ATTENTION ASSISTMonitors driver behaviour (via steering, etc.) for signs of fatigue or reduced attention; gives warning.Standard or frequently included.
Crosswind AssistHelps with vehicle stability during strong side winds.Standard in many markets for Marco Polo.
Highbeam / Headlamp AssistAutomatically adjust headlamps (dipping / bright) to avoid dazzling others.
These are the other features in the 2019 Marco Polo which are relevant, and which PRE-SAFE is integrated with (or complements). Some are standard, some optional, depending on the variant / package you have.
Thank you , never seen this list before ,l believe l originally set up the seat belt tensioners using the centre touch pad , it always slightly tightened on switching on ignition, l will do a search for fuses , will also disconnect seat belt when in motion to see if warning comes on
What model year do you have carol?
All was well , but warnings came on again today after 150 miles on motorway, when l got of ferry 2hrs later it was all ok , even after driving another 100 miles to get home all seemed to be working
I wondered if l should use the factory reset on the steering wheel home button
There probably are a load of fault codes related to an abs sensor. They will point to which one. It’s a relatively cheap and easy fix.
Glad you eventually got this sorted. The sensor is a wear and tear item really in that over time, like us all, it ages, oxidises and fails.
Be worthwhile probably is all investing in a code reader and learning how to swap them out ourselves maybe. Luckily it’s not that expensive to replace though.
Yes you are correct, as seems like a frequent problem, l think it was £45 to have the assessment, l wouldn’t know what to buy and how to use it, They didn’t even need to take a wheel off to replace , so guess it must have been a simple plug together bit
Although I haven’t searched myself I believe there’s a video somewhere on YouTube. I was under the impression that the wheel had to come off but every day is a school day.
