Leisure Battery
Ian M
Dear All
Can anyone advise on the specifications of the Leisure battery in a 2018 Marco polo
Battery is located under passenger seat
Is there a part number available as I can’t locate it in my manual and MB aren’t that familiar with the vehicle configuration
Any / all advise welcomed
This is what we have. We asked the dealer if there should have been a different battery for the leisure (auxiliary). We were told “Mercedes fitted the same for both”. However many people here have fitted Lithium. The starter battery is expensive as it’s supporting stop and go. Therefore I’d take advice. I know also there maybe changes in the charge relays to allow the alternator to charge Lithium.
Thank you for taking the time to reply
Seems after further digging on here that maybe a different battery should be used. Even though shows as good have to say we do have occasional issues with roof, seats and fridge. All seems to point to battery not holding charge. I’ve been pointed to this as an appropriate replacement
Or this AGM version
I have replaced both Starter and Leisure batteries with two of these from Costco, all is working OK.
I have recently had issues with both my batteries (2021 MP but I think batteries are the same on the previous model - the space for them certainly hasn't changed)
Car battery is 95Ah
Leisure battery is 80Ah
Both are AGM batteries.
I have now fitted a Lithium battery (180Ah Titan) but I would recommend you get a DC-DC charger if you wish to go down the Lithium path - it's not a bad idea even sticking with the existing battery - no risk of the relay sticking and draining the car battery, and some can also condition the leisure battery
By the way I specified Titan as not all Lithium batteries are the same dimensions - many are apparently too tall.
XEG12 do you have more details about your setup?
Have you replaced the AGM leisure battery with the Titan or have you added to Titan in to the system somehow?
My leisure battery is 7 years old (2018) and seems to be quick to discharge so looking at replacements.
@AshJones beware, the Titan battery mentioned above is a lithium battery and you can't just swap the original AGM battery for a lithium battery without a DC-DC charger. Doing a straight swap can cause fire and/or damage your alternator.
Beste allemaal
Kan iemand mij adviseren over de specificaties van de Leisure-accu in een Marco Polo uit 2018?
De accu bevindt zich onder de passagiersstoel
Is er een onderdeelnummer beschikbaar, aangezien ik het niet in mijn handleiding kan vinden en MB niet zo bekend is met de voertuigconfiguratie?
Alle adviezen zijn welkom
