Samebutdifferent
This was only available in the "Aqua Marine" color last year and I didn't want that.
Saw that colour on an MP up in Keswick a couple of weeks ago, agree it's not nice at all
It’s the 2021 model, and no information was given. Just a book to read and on your wayHi Paul, welcome along to the forumand sorry to hear of your issue with the pop-top fabric. Can I ask what year model you have?
I have a 2017 MP and the control console will not allow you to open/close the roof without first dropping the drivers window, I assume from your post that your system in fact does allow this to happen?
Can I ask, did the supplying dealer give you a vehicle handover where they explained this risk and other features of the MP?
It’s the new Mbundu, it does stop half way down but certainly now warning, it makes me fearful of closing the roof. Which shouldn’t be the case on a high end vehicleVery sorry to hear about your roof problem Paul.
So much for dealer handover !
Is it a newer MBUX or Cammand system? As has been said the interlockiinterlocking provides a reminder to open a window and won’t start lowering. It also stops part way down. If it doesn‘t do this, there might be a fault in the interlocking in which case you might have some redress.
It‘s belt and braces, but many people open the side door when closing so that there is absolutely no chance of the increased internal pressure forcing the bellows outwards.
Regarding other comments about squeaks, I wonder wheather the locking bolts need adjusting/greasing.
Finally the wardrobe light: Having left the wardrobe door open for a considerable time and almost flattened the battery, mine is now permanently turned off with a neodymium magnet taped to the door.
MBUXIt’s the new Mbundu, it does stop half way down but certainly now warning, it makes me fearful of closing the roof. Which shouldn’t be the case on a high end vehicle
No hand over, I don’t think the local dealer had ever sold one. The model I have is the 2021 model with MBUX controlHi Paul, welcome along to the forumand sorry to hear of your issue with the pop-top fabric. Can I ask what year model you have?
I have been out to my van tonight to check and i have to accept that a warning to open a window does come up when you operate the roof. It does stop at a point which i assume is when you are to check everything is retracting correctly. But i myself write plc software for food production lines, and it would be so easy to create a logic in the software to open a window automatically when retracting the roof. Yes i should have been more careful, but i work in an industry where we create safety systems which are designed to protect idiots. I guess I’m the idiot on this occasion.Hello and welcome Paul
GT is correct above. When I hit the roof button it also stops after a few seconds with the window icon so effectively you have to press the button twice to operate the roof
I accept this, but a simple software mod to force a window to open Would be a sensible solution and save a lot of heart ache, i maybe speaking only for myself but i generally work most things out without reading 90 page manuals, life is too short.The manual is about 90 pages not 400 and it clearly states to open a window or door before you operate the roof otherwise the bellows could be damaged.
It goes on the mention it a further three times plus when actually doing the operation the window symbol flashes in the display.
Unfortunately for you I'd say MB were right to say it was your fault.
It's a canvas that can now be ordered from the configurator from the factory and OEM canvas. Mercedes parts desk will order it and it's not much different than if the original canvas was damaged and needed replacement. Not under warranty in this case though obviously. ;-)Dread to think what would happen if you asked a UK dealer to swap out the canvas for something else
I also have a background in software. For me, automatically opening anything is probably not ideal, e.g. you wouldn't be thankful if heavy rain was blowing in. But I agree, a simple software function to prevent closing the roof until either front window or the sliding door is open would work perhaps....it would be so easy to create a logic in the software to open a window automatically when retracting the roof....
If you have a roof replacement by MB they have to disconnect and remove EVERYTHING (I mean everything) from the original roof as the new roof supplied is the fibreglass part only (in primer)....so I would guess that any MB dealer who has done a roof replacement should in theory also be able to do a canvass replacement....also any Westfalia roof specialist should be able to carry out a canvas replacement.Dread to think what would happen if you asked a UK dealer to swap out the canvas for something else
OK, maybe call the after-sales manager from the dealership and discuss the issue. Explain you didn't get a handover of this clearly critical component and that you are just upset about the current condition of the roof.No hand over, I don’t think the local dealer had ever sold one. The model I have is the 2021 model with MBUX control
Hi Webbah. The new roof on our van is not quite straight and needs an adjustment to even up the gaps in the gutters either side. You mention the experienced technician above - please could you share the dealership and tech name and also, do you know how they adjust it? I'm seeing the dealer here who will hopefully know, but a reference they could talk to would be useful. Many thanks. Tee.I was just at the service center and fortunately there was a very experienced technician there for Marco Polo's. He discovered that the alignment of the top was just a little off by about 3-5mm to one side, and about 2-3 mm too far back. I didn't have time to have them fix it today, but they will sort it out for me in the coming days. He assured me that all noise would be gone once it is aligned properly. Also, he informed me that he can order a new canvas in the same color with a window on the front. This was only available in the "Aqua Marine" color last year and I didn't want that. I'm getting a quote on that as the front window is something I really would like when parked lakefront or oceanside. ;-)
Ik heb het ook ben al drie keer bij garage is niet verholpen helaas het lijkt er scheef in te zitten aan bestuurderskant hiel strak en bij bijrijder kant veel ruimte ze hebben gedistribueerd het aftestellen 3 keer dus niet gelukt ligt nog steeds mislukt. Als ik aan de krappe kant doek zit, is er een driedubbel tussen been het stil. Zou beter moeten kunnen. Vr.gr.RobIk heb een ander probleem met mijn hefdak. Het piept aan de voorkant als ik over hobbelige wegen rijd of in de bochten van de bergen. Ik ben er al mee naar de garage geweest en ze hebben geprobeerd de boel aan te draaien. Dat hielp een beetje, maar ik word er nog steeds gek van. Daarna heb ik geprobeerd de rubberen afdichting schoon te maken en te smeren met "GummiPflege Stift". Dat leek iets te helpen, maar het piept nog steeds. Vervolgens heb ik gekeken wat ik aan de binnenkant kon doen en wat dun vilt rond de metalen contactpunten aangebracht (de zachte kant van klittenband). Dat hielp ook een beetje, maar het is nog steeds niet stil. Ben ik de enige met een piepend dak? Als je het eenmaal hoort, krijg je het niet meer uit je hoofd en ik word er gek van, zeker voor zo'n dure auto. Als laatste redmiddel laat ik het misschien nog eens proberen door de garage, bijvoorbeeld door het dak beter af te stellen?
