I had a little adventure last night. 30 miles in to my exit from Cornwall at about midnight the dash popped up the tyre defect warning whilst cruising at 70mph. The OSR was showing low, I thought it might just be low so keep an eye on it and see. The pressure was dropping rapidly so I backed off and checked the map for the next services. Fortunately just round the corner...
So I pulled over on at the Esso on Bodmin moor, jumped out and it was hissing quite loudly.. so I found a nice well lit spot to park and set about changing the wheel. I’ve not had to do this much in the past, just once I think on a Metro. Anyway it’s not a job anyone would choose to do, counting my blessings, it’s a warm and dry evening, the light is ok and I’m on good ground with a slight slope facing down hill but it’s the best I could get.
We carry chocks so my first job was to chock the front wheels, I dug out the tools, and set to work having to re-adjust the jack after I was so careful to make sure it was level.. the tool kit is great, it all worked well, no scraped knuckles, had some fun finding the access point to winch down the spare, I never read the hand book . But done-and-dusted in ~30min, with the flat back under.
A few things to note and the point of this post really.
1. remove the key from the ignition or at least put the handbrake on - I completely overlooked this and assumed the free play in the rear wheel was just how it is, never even thought to check as far as I was concerned the handbrake was on.
2. Be very carefull when opening the rear sliding doors, no issues here for me but I keep the wheel locking nut under the bed so had to get in the side to find it, tools can stick out..
3. When fitting the spare don’t use the locking wheel nut, use one of the standard nuts. This makes re-tightening the nuts with the short brace much easier and safer because the actual interface between tooling and nut is far more reliable.. I actually stood on the wheel brace to undo and tighten, then checked with my hands for a final time, a satisfying crack.
All in all I actually enjoyed it and I am beginning to feel that we (the van and I) are finally bonding. I love these unexpected events that happen on journeys and to top it off a young chap pulled up beside me and asked if I was ok and did I need a hand.
