pons_sport
Hi, I would like to intall 12v dc to 220v ac inverter using the leisure battery and the oem outlet installed in the kitchen. Anyone have done this modification?
thanks GT!
Here is an interesting video describing inverters and the myriad different types...seems like a fair bit of investigation required before leaping in.
Hey Ian, did you already manage to find a solution for this? Would be great to hear your experience, I'm currently looking at a solution myself.this is a great topic, i bought a 200w solar panel system but still cant get 240v from the 240v socket- all advice welcome, thanks folks, and hopefully we can get to enjoy our amazing MP's in 2021
Hi @Apojapo, Hi folks, so sorry for the delay, been a bit manic at work. So I fitted two solar panels from https://www.solarcampersolutions.co.uk - really helpful chap, panels are working really well. My need for 240v is really only laptops. I am now looking at taking a fused connection from the aux battery but nothing heavy at all. If the community are interested. Also there is a great route for running the cable from the Solar Panel into the MP via the back light. Then! bought a Gibe Bus Tent, I have two say, its brilliant! it takes 5 mins to inflate with the manual pump. I hope everyone is able to start getting away and enjoying our lovely MPs! - We went to West Wittering today, parking for weekdays is only £2.00 but you need to do it via Just Park - do not pay anymore for weekday, weekends is £7.00 or £8.00. - Oh! last one, we added a CampLux Hot shower by removing the shower head from the Westfalia shower hose, so we now have a hot shower or just hot water. Sorry for the download but we cherish the MP and its been great to add tho water, solar, inflatable drive away awning etc.Hey Ian, did you already manage to find a solution for this? Would be great to hear your experience, I'm currently looking at a solution myself.
Inverters are terribly inefficient you could well flatten your battery using that without the engine running. I killed my battery charging 2 camera batteries on one of those. If your laptop uses a USBc type cable you should use a usb type adapter.. if your laptop is old it’s worth checking what the power supply is delivering some were 12v so you could just make up a cable.Hi there. I'm a new member. I bought a MP (2015) a few months ago. We love it!
I want to charge my laptop while not having external electricity and no solar panels.
It's just for working a day when on holiday.
I have a converter 12 - 220 V, but it should be connected in a cigarette lighter box. And they don't work with the engine off.
Anyone any ideas?
Thanks!Inverters are terribly inefficient you could well flatten your battery using that without the engine running. I killed my battery charging 2 camera batteries on one of those. If your laptop uses a USBc type cable you should use a usb type adapter.. if your laptop is old it’s worth checking what the power supply is delivering some were 12v so you could just make up a cable.
I’m not sure what the 2015 mp comes with but later models had 12v outputs in the back that work with the ignition off. You could always fit one or get one fitted that is constant live.
Hi there,Hi there. I'm a new member. I bought a MP (2015) a few months ago. We love it!
Anyone any ideas?
USB-C is a complex beast. Many laptops do charge over USB-C, but they often use 9V, 15V and 20V as well as 5V. A normal 5V smartphone USB-C charger won't work with them.Most new laptops will charge via USB’c it’s probably worth considering getting a decent quality 12v adapter rather than using the 240v mains adapter.
