Douglas Smith
I find the need to remove the fuse for the water pump a royal pain when draining the fresh water.
A little rooting around found the connection between the feed and the pump, under the base of the wardrobe.
I used a project box from Maplin and some heavy duty auto cable to make a breakout switch.
I mounted the box with Velcro inside the wardrobe, so now I just turn the key to isolate the pump.
The connection uses crimp spade connectors, so no permanent modification to wiring.
The keyswitch was the best fit in the box.
