For anyone considering swapping out the OEM 2-pin internal mains socket for a UK 3-pin socket I can confirm that it is an easy 5 minute job no more difficult than changing a plug (remember those days
The only issue I had was that the new socket that I ordered, I thought was black but arrived grey so I shall swap again once I source a black unit. These are the steps I took:
1. Unplug mains lead and switch off at isolator switch
2. Gently lever off the switch cover surround that goes around the three units (Light switch, USB socket and mains socket)
3. Remove the four screws holding the mains socket in place
4. Remove 2-pin socket and replace with UK 3-pin (make sure to use a backing box to cover the inside electrics)
5. Screw new socket in place and replace trim
6. Test with a socket tester
There are loads of sockets available. Just google 'c-line socket'. I used...
Socket and Backing Box
