Aux Battery Malfunction warning
Gambell
Hi, I'm new to the chat, bought a 2018 MP a few months ago and have spent quite a lot of time fixing some issues myself and resorted to a garage for the more difficult ones! I thought I was out of the woods and now the Aux Battery Malfunction warning comes up most days. It also prevents the cruise control from working. From what I understand the Aux battery is a the small motorbike battery under the drivers seat and accessed from behind the seat. It looks difficult to get out but I managed to get a volt meter across the terminals while in situ and its reading 12.8V with the engine off. Has anyone else had this problem and if so what was the solution? There does appear to be a small component fixed to the side of the battery box which is connected to + side of the battery (see photo). Maybe this is a voltage regulator. The output from this was 12.4V.
I had mine replaced on Monday.
Warning message came on just before its
B service last week.
New battery was £109 + labour
The mechanic did say it was bugger to do because of where it sits
That's good to know. I tried to get mine out, virtually impossible. It's like keyhole surgery. You also need insulated socket wrench otherwise there would be sparks everywhere when you try and remove the cables from the battery terminals.
I’m confused.
My auxiliary/leisure battery is under the passenger seat in my right hand drive UK version. It’s a full size battery as opposed to a motorcycle size and I have removed it before to photograph the details and measure it as I have had a couple of malfunction warnings and have been suspicious of it’s reliability for a while now.
There isn’t another smaller battery hidden somewhere is there?
I have a 2017 MP.
I’m confused.
I have a 2017 MP.
Yes
MB use a second under the drivers seat.
Pull plastic cover off and you’ll see it. Similar to bike battery.
Is a back up to main battery, helps with stop/start etc
