Aux Battery Malfunction warning
Gambell
Hi, I'm new to the chat, bought a 2018 MP a few months ago and have spent quite a lot of time fixing some issues myself and resorted to a garage for the more difficult ones! I thought I was out of the woods and now the Aux Battery Malfunction warning comes up most days. It also prevents the cruise control from working. From what I understand the Aux battery is a the small motorbike battery under the drivers seat and accessed from behind the seat. It looks difficult to get out but I managed to get a volt meter across the terminals while in situ and its reading 12.8V with the engine off. Has anyone else had this problem and if so what was the solution? There does appear to be a small component fixed to the side of the battery box which is connected to + side of the battery (see photo). Maybe this is a voltage regulator. The output from this was 12.4V.
I had mine replaced on Monday.
Warning message came on just before its
B service last week.
New battery was £109 + labour
The mechanic did say it was bugger to do because of where it sits
That's good to know. I tried to get mine out, virtually impossible. It's like keyhole surgery. You also need insulated socket wrench otherwise there would be sparks everywhere when you try and remove the cables from the battery terminals.
I’m confused.
My auxiliary/leisure battery is under the passenger seat in my right hand drive UK version. It’s a full size battery as opposed to a motorcycle size and I have removed it before to photograph the details and measure it as I have had a couple of malfunction warnings and have been suspicious of it’s reliability for a while now.
There isn’t another smaller battery hidden somewhere is there?
I have a 2017 MP.
I’m confused.
I have a 2017 MP.
Yes
MB use a second under the drivers seat.
Pull plastic cover off and you’ll see it. Similar to bike battery.
Is a back up to main battery, helps with stop/start etc
Ok so I found my auxiliary battery and have removed it to measure and test.
Getting a huge 10.8v after a pretty long run, so it’s about done. Measured it carefully and it needs to be no more than 130mm high due to constraints of the battery box. Plenty available at 145mm height, which is no good, but 130mm seems almost impossible to find (apart from official dealers of course at double the price)
Has anyone managed to source a suitable replacement?
Don’t know if you’re on the Facebook group. If not join that and search, it’s a well discussed topic. I posted here the other day but that might have been start/stop battery and I don’t want to confuse matters. (Like why this just went into italics) who knows.
I’d also check out Costco if you are a member once you get the specifications or try a local Indy car electrics place.
can the OP @Gambell advise what the “Aux Battery Malfunction warning” error code look like?
Did you take a picture of the error? Did it come up on the dashboard display?
Mine threw up another presafe features limited warning yesterday but no abs/esp lights were illuminated. Need to see if the code reappears and get it scanned by someone local.
Hi, Mine is also a 2018 model. I have three batteries. The MP came with three. One for the engine, one auxillliary and one for the main cabin compartment. At least I think this is how it goes but would appreciate clarification if not. I have had to have the auxilliary battery changed once (which was the first time since 2018. And the second battery which apparently is for the lights and fridge etc in the back I had to have changed a week ago for the first time since 2018.
I was told that the draw on this battery when you set off and have the fridge full for a trip and put the fridge on, is a lot and that it might be an idea to cool the fridge from home plugged in first of all......I found this to be shocking, as I cannot imagine Mercedes would make something which is not 100% perfect.
Any comments?
