Webbah
Hey man,Hi Webbah
Interesting as im in the process of doing this to my 2018 MP ( No Air)... Ive tried everything, currently on 18'' with 235 x 55 x 17 which look great but... just too close..
So in easy terms what do I require - Twin-Monotube Projekt AT Konkave in Granit fitted with (my choice) General grabber AT2 235 x 55 x17. (My standard ones nt enough offset)
Where can I order and whats the precise wheel sizing - Im trying to get details to the UK distibuter.
Any info great if you had time, Thanks Crispin
I did a quick search and it looks like there should be some distributors in the UK.
I have the 17’s with offset ET40. Can’t help with the General Grabbers, but the BFG’s work well in the 225x65R17 with load rating 103/107. Don’t think the 235x55R17 will work.
With the BFG’s I had to use a heat gun and crow bar to mold the inner wheel well plastic at the rear of the front wheels. Not too difficult but I did it twice before it was perfect. I can now go full lock in turns including with angles and articulation and it doesn’t rub. Super happy with them and glad they are all season so no swapping.
I’d probably sell the Grabbers and switch to the BFG’s in the size mentioned. The offset ET40 will push them out a bit (mine are flush which is great), but I suspect you will not be able to mold the plastic liner enough to turn hard with some articulation. Could be dangerous too!
Hope it helps! Ping me again if any more questions.
wheel you got, so just want to source them easily in Granite in UK ( white Van) have the Grabbers fitted/tpm sensors pay get delivered and enjoy the offset and strength, as we too load ours up to the top with junk and towing trailer on on un made roads gravel/snow.
