The fat controller
Hi all
At the risk of turning into a spammer, I have another issue I'd like opinions on.
The front of my awning casing isn't closing up completely. I've attached pictures below.
You can see that it's marginal, so not critical by any means but it's annoying and does lead to water ingress, which inevitably then drips down the drivers door.
I've tried winding all the way out and back in - there does seem to be some unevenness in the fabric which I guess could be causing it, but I wasn't able to resolve this simply by winding fully out and then back in. I've also applied silicone to the lower edge of the casing in an attempt to get the flap to slide up over it and seal but to no avail.
So I'm wondering, is this normal? Do those of you with factory awnings find the same or do they close neatly? And do you have any experience or tips on how to deal with the issue?
Many thanks
Phil
Many thanks
Phil
