Thanks for the help I can't open the tank. It's impossibly stiff. Do I need to open a tap or anything first, is it under pressure?. Also could I put cleaning solution in from the outside filler cap?I bought this from Amazon works very well.
I clean once a year in Spring, open the water tank lid from the wardrobe, follow the instruction, a bottle is probably enough for 4 uses.
Also drain the water if not in use.
That’s what I did. Seems fine to me.Thanks for the help I can't open the tank. It's impossibly stiff. Do I need to open a tap or anything first, is it under pressure?. Also could I put cleaning solution in from the outside filler cap?
CheersThat’s what I did. Seems fine to me.
