W447 roof rail nuts blocked by rivets – anyone found the right ones?
jakuza
Hi all,
I have a new Marco Polo W447 (2026, delivered in October) and I'm fitting a flexible solar panel on the pop-top roof using the original T-slot roof rails. The van is on a long-term lease, so everything has to be fully reversible: no drilling, no modifications.
I bought some rectangular M6 nuts that slide perfectly in the rail. The problem is that the rails can only be loaded from the rear end, under the plastic end cap, and the floor of the rail is fixed with rivets whose heads stick up and block the nuts. In the attached photo the orange arrow shows the first rivet: no nut will slide past it. All the other rivets are the same, so only the rear section of the rail is usable.
Before posting I searched extensively for original nuts, at Westfalia and at several UK, German and French van accessory shops, without finding a part in stock or a reference clearly matching this rail.
My questions:
1. Are there original Westfalia or Mercedes nuts designed for these rails that clear the rivets? If so, do you have the part number, or know where to buy them?
2. Has anyone found "drop-in" nuts that go in through the slot and turn 90°, sized for this rail? The slot is about 16 mm wide.
3. Otherwise, how did you fix bars or accessories along the full length of the rail?
I'm based in Paris but happy to order from anywhere in Europe. Any tested solution or supplier tip is very welcome.
Thanks in advance!
