Squeaky rear brakes
WDJ
My 2021 MP has developed a high pitched squeal from the rear brakes (like a whistling sound). MB replaced the rear shoes and hand brake cable to fix it. It didn't work. Has anyone experienced this and what was the resolution?
Yes, I have and there is also a thread on here about it if you search.
For me the squealing was often but not always present but, when it was, the squealing went away when I touched the brakes. Is this what you have? I took it to my MB dealer twice (£85 investigation fee each time) and they said they couldn’t hear it but thought it was corrosion. They said they could replace the discs but there was no guarantee it would work. Faced with this lack of confidence I took it to an independent specialist and they diagnosed the same but were confident they could fix it and said if it didn’t work they’d keep trying at no extra cost. They replaced the corroded rear discs (corrosion had created a lip) and cleaned the corroded calipers so they fully released so the pads weren’t touching the lip on the discs and causing the squealing. Cost about £400 if I recall correctly but worth it because the squeal was driving me nuts.
Thank you Roy. Sometimes the squealing stops when I touch the brakes but not always My van is back at the dealership this week.
I had rear wheel squealing develop on my 2022 MP after a year of use. Initially started on steep inclines/descents in the Alps. MB dealer could find anything. Then problem became more persistent. Took back to MB, still no idea. Took to a different MB dealership, same answer. Eventually took it to an independent brake specialist. They found calipers were ok, but pads had been sticking, creating a groove on the discs. Replaced both real discs and pads . Cost £465 ( out of warranty by this time ☹️) Problem solved
Don’t know why the MB dealerships couldn’t find this out
