Sliding side door and rear door stop working
RogerBrierly
Hi, after no problems some strange things happened all on the same journey from Devon to home. An orange ABS not available symbol appeared and the parking brake illuminated in orange on the dashboard. Having stopped to check it was safe to continue I then found the navigation was showing route not mapped (I was on the M50!) and on returning home the electric sliding side door and tail gate stopped working electronically. Is there a key fob reset option to reboot these sort of issues, has anyone experienced similar and any ideas what type of help I need ie auto electrician, MB garage, or a hammer ! Many thanks for any advice.
Basic questions;
A) have you tried the other key fob?
B) do you have a code reader or can get access to one? If not might be worthwhile talking to an Indy to scan the codes.
C) has a presafe features function not available appeared? Could be an abs sensor issue, see other posts on it.
Can’t help on the sat nag issue it’s probably woefully out of date like most of the MPs on here. It makes zero sense economically to update (as the update itself is not only costly but also possibly out of date too!!).
Your issue with the abs may reset after locking and leaving the car for some time but if it’s a sensor chances are it’ll come back. Not an expensive issue but expect like £150-200 to diagnose and swap out. It’s also a relatively easy diy repair which I believe is covered on YouTube (though haven’t seen it myself).
Please update the thread. The more knowledge on here the better.
