Roof actuators & scissor hinges
Ragga
Could any one recommend a company / dealer that really understands the roof mechanism for the pop top roof (ideally in the Midlands though I will travel for expertise). We had an issue where one actuator lowered faster than the other making roof closure a little bit tricky. I suspect one of the actuator position sensors is inaccurate.
Hi Ragga. We had a similar problem with our roof about six months ago and took to Peterborough Mercedes who did resolve the problem by adjustment. Don’t know what the cost was as completed under extended warranty. Sarah in servicing is a good start.
Hi Ragga. The actuator failed on our pop top. Roof couldn’t be lowered! Eventually Mercedes of Taunton fixed it. They were good…but very expensive! If you find an independent company that can fix it would you post it on here please.
I would contact Customhaus 01793200721www.customhaus.uk
They are near Oxford
I can highly recommend Mertrux in Derby. They are outstanding - could not recommend them more highly. Try contacting Jon Anderson in their excellent Service department on 01332 290290.
Hello Vickim
I tried Customhaus but their suggestion was to refer back to Mercedes.
Hello NomadS.
Thanks for the suggestion. I visited them today. Looks like just a bent rear scissor hinge was the only casualty. Roof raised & lowered fairly evenly.
Hello Vickim
Hello NomadS.
Hello PhilandSal
Finding an independent proved difficult. I think the fact it is a stepper motor actuator with position control puts most independents off
Hello TwoRs
Mertrux was just a little bit closer & Jon & his team seem to understand how the Marco Polo operates. Not quite out of the woods yet & will give update when the hinge is replaced.
Hello Vickim
Hello NomadS.
I'm glad it was of help – Mertrux is the only Mercedes dealership I know that really understands the Marco Polo, and also gives the most incredibly personal service and real attention to detail. They are outstanding.
We are now having similar problem, roof been going up un-evenely and had now stopped working all together and triggered alarm to suggest roof is open when its closed. If we take our fuses out for a bit and put back in it starts working again but one side going up quicker than the other. We have messaged Mertux to see if they can help.
Did anyone else find an alternative solution. I am very worried about entering into high cost repairs with Mercedes that may or may not work. Our local dealer is really unhelpful.
We are open to any practical solution and prepared to replace with a manual roof if needed.
