New gas struts for the roof
Torben
Hi all,
I’m trying to find upgraded gas struts for the pop-top roof on my Marco Polo, and I’m hoping someone here has solved this before.
My current struts are:
  • Stroke: ~400 mm
  • Rod/tube: 10/22 mm
  • Extended length: approx. 1060 mm (eye to eye)
  • Force: 450 N
They work, but I’d like a bit more lifting power – especially when there’s some load in the roof.
What I’ve found is that the main challenge isn’t really the stroke, but the length of the cylinder itself. The body of the strut is longer than what I typically see on standard/off-the-shelf options, and therefore the total extended length becomes difficult to match with more common struts.
So my questions are:
  • Has anyone upgraded to stronger struts with similar dimensions (especially cylinder length / total length)?
  • What force (N) did you end up using?
  • Any suppliers (UK/EU) that can make these to spec?
  • Has anyone solved this in another way (e.g. different mounting points, helper springs, locking struts, etc.)?
I’m open to any ideas or workarounds.
Thanks!
Hello! I have the same questions. Did a little bit of a research and thinking of ordering Stabilus Lift-o-MAT 7924WE 0500N instead, 10% stronger should be. The main reason for change is that upper tube of the strut on the right side poped out from lower so i need to adjust it in order to close. Found this youtube where he seem to have the same problem. i dont know german so guessing..
Sounds good I have a hard time finding someone who would sell them in Europe. Also I would like a little more lift power to endure that it would be easy to lift with a roof rack …. Have you bought Them allready ?
