Moving rear seats
My rear seats are very stiff to slide back and forward - almost need 2 people. Is this normal?
I don't think this is quite right. Mine are heavy, but easy enough to slide.
Perhaps try to pull the lever up with your left hand but use the metal handhold (drawer front) to do the actual pulling or pushing??
Rusty888
Thanks SteveR and SteveB
Have used SteveR’s suggestion
Your replies give me more ammunition when talking to MB who have not been very helpful over this issue
Do either of you use any sort of lubrication on the runners?
patas
Mine is the same, hard to move one person alone. I have to move mine, sitting in the seats and pushing
Enviado desde mi Aquaris X mediante Tapatalk
Richard
mine is impossible with one person and very difficult with two people. I have to have to second keratin pushing from the tail gate.
Scrumpy
Mine is fairly stiff, I'm quite strong no boasting!!
so can see why it's a struggle. I've thoroughly cleaned out the runners but I might try WD40 to see if that might help the seat slide better.
Be careful if you place your knees / legs against the front of the seat as the previous owner had on mine.
You'll damage or be pushing against the seat buttons.
Finally got mine to stay in place after becoming loose.
As others have said, make sure you grip the metal bar, it will stop you pushing with your legs.
DPS20K
Are you sure you are pulling the lever up all the way? My seat is stiff if you don’t pull the lever right up. It almost seems to have two positions and has a tendency to stop half way if you don’t pull hard.
