Maro height restrictions
Hyrule
I was keen on the 1.9m height of Marco but has anyone actually measured the height? Im asking because many car parks have a 2m limit but often the bar is dangling from bits of chain that look suspect. In addition, many car parks around my are (Milton Keynes) now have 1.9m restrictions. Im not enthusiastic to just drive at them. Perhaps I need a stick 1.9m long to carry in the bck of the van?
I agree, the less than 2m is reassuring. From recollection the data sheet on the VW California is a little misleading as the height of the vehicle as stated is not to the top of the pop top but to the original roof height.
However from recollection the height of the MP is 1.98m (actually on the lower part of the dash to right of steering wheel it states 1.99m). This means that it is only around 1/2” (sorry - I still work in imperial measurements ) below 2m. I have never gone under a 2m height restriction- I just think it is too close to call. A 2.1m height restriction is bad enough
Mine measures 1.97m. highest point is just about in the middle of vehicle. No awning and 245 45 19 tyres.
I've seen 1.8m and 1.85m signs, Bristol have sub 2m carparks iirc
Its one of the issues we have as we use the MP as a car, 1.99 v's a 2.0m is a little close. So I now look out for outdoor carparks and check in streetview to see of there is a restriction bar over the entrance. It is a bit of a pain sometimes as it means preparation rather than just turning up
Would I be talking out of line if I mentioned roof blisters at this point....:D
Seriously though adding a solar panel probably tips most MP's over the 2m limit....I look out for other vans in the car park first.
There is a car park I use which has a fixed bar set at 2m but which is a grass track. The thousands of vehicles passing through have worn ruts in the grass and I regulalry see high top VW's and Transits parked up in there :)
Yep I spent a while contemplating the accuracy of the height sticker supplied with our MP. I sort of measured it but without level ground and a decent straightedge it’s quite difficult to be accurate… I then concluded that the roof conversion isn’t any higher than the roof bars that would normally be in its place so chose to accept the stated height.
We have used several underground public and private hotel car parks in Europe that have been very close, we have to pull up outside and remove all the surfboards and roof rack and stash them inside before we can proceed. I usually remove the roof rack but used it for some building materials in the spring and decided to leave it on since summer is here and it’s bound to get used more.
it’s the roof rack that will cause us grief because it’s not always fitted..
Hello all. Fwiw, my wife and I took our 2021 MP through a 2m limited tunnel (A86 w of Paris) and had no problem. It's was a little spooky at first but after a second time, no worries.
Regarding blisters, our local Mercedes trucks dealer replaced our blistered poptop last fall. No questions asked. Hopefully, Wesfalia has been in contact with a fiberglass boat builder, or two, and they won't reappear.
Ik was erg gecharmeerd van de hoogte van 1,9 meter van Marco, maar heeft iemand die hoogte daadwerkelijk gemeten? Ik vraag dit omdat veel parkeergarages een limiet van 2 meter hebben, maar de stang hangt vaak aan een verdacht ogende ketting. Bovendien hebben veel parkeergarages in mijn omgeving (Milton Keynes) nu een hoogtebeperking van 1,9 meter. Ik heb er geen zin in om er zomaar tegenaan te rijden. Misschien moet ik een stok van 1,9 meter lang meenemen achterin de bestelwagen?
Hij is 1.99m.
Fill it up with petrol, pick up a couple of hitchhikers and the suspension will settle down nicely. Seriously though, I’ve never had an issue and the lowest barrier said 1m 96cm. The height stated is generally the lowest point inside the car park, which can be in tucked away spaces, or close to pipework. Using a bit of common sense you can park safely in any that say 2m.
The infotainment says it’s 1.9m but does that include the awning?
I’m afraid to go into multi story car parks as well! The awning sits quite high compared to the roof and dread smashing it off!
I have a 2025 model and my height is 1.99 m with the Westfalia roof. We are always wary of poorly constructed car park entrances and never try the 2.00 m limit. The trick is sometimes to enter through the exit :) There are rarely any restrictions in this direction, but you have to do it early in the morning or late at night. In some underground car parks with a height restriction of 2.10 metres, you can enter, but generally only on the first floor. Mercedes has ended its subcontracting agreement with Westfalia and is going to release a new roof? Watch this space...
Translated with DeepL.com (free version)
