I have a problem charging the leisure battery with the engine, the status bar graph remains black.Charging with an external 250V source the control display works normally.
Shortly after switching on the engine the charging bars are initially correct, the first and last bars are black then after a few seconds all the bars turn black and remain black while the engine is running. The battery voltage status indicator seems to be working correctly showing that the battery is being charged from a low of say 12.8v to 13+ depending of the drive duration. Parked up with 13.2V showing, at the end of 4 or 5 days with nothing switched on the battery voltage shows 12.8V.
So, do I have a battery problem or a central control unit problem?
All help greatfully received. Thank you.
