LED light in wardrobe
Pip J
we have just picked up our new MP yesterday. The LED light over the vanity mirror in the cupboard appears to be on permanently even overnight. We guess this cannot be right! How do we turn it off?? Thankyou
Could be switch not being fully depressed, is door fully shut? Try pressing it slightly to see if there is further movement that switches off the light which would suggest door or switch needs adjusting.
At the risk of sounding stupid..... where is the switch? !
We thought it might switch off when door closed but no...
Both wardrobe sliding door and vanity mirror door need to be closed for light to be off, if it is still on in that situation I'd let the dealer sort it as it must be a faulty switch.
This happens on our MP and we have to check that the door really is fully closed. A couple of mm open and the light comes on.
Ours needed a part which they've had to order in from Germany. Still waiting currently.... they've disconnected it while we wait so as not to drain the battery...
Following up on this thread:
Does anyone know where the switch is ? And can it be disabled without pulling fuses?
When sleeping downstairs I would like to leave the sliding door open to put things in.
Currently this is not possible because the mirror light comes on.
It’s a pity the moulded panel on the opposite side of the cabin doesn’t have a lip on it so that it could provide a small shelf It would then could leave a phone and small objects there. That’s design for you - looks pretty but with more thought could be functional !
I taped a small magnet over top right internal corner of vanity door and this activates the magnetic switch turning light off
