Fridge thermostat
grettule
Hello everyone.
My fridge has fault and thanks to threads in the forum I know I need to change thermostat. I contacted Dometic UK they said they do not stock. Where it is possible to source thermostat and how do I know what model my fridge is.?
MP is 2018 . I see many say Dometic UK, and I used product code that I found on forum, apparently too old.
Please advise ?
Thank you so much. I will try to order and see how it goes. I will update the thread.
Good luck. Think it’s quite fiddly but if you follow the hints and tips on here and in the Facebook group, particularly using some kind of snap lock connector and using the old part to pull through the new I imagine it’s doable.
What I’m not looking forward to, should it happen is if/ when then fridge hinges break.
