Faulty level sensor, fresh water tank
Grahammf
Hi
has anyone else had this problem and if so, how did you manage to get it sorted out?
The warning triangle in the bottom left of the central control panel is on, which then shows an icon of a water tank with a diagonal line through it. According to the handbook this means that the level centre sensor of the freshwater tank is faulty. It recommends you have the level sensor checked at a ‘qualified specialist workshop’. Our local MB garage has been less than helpful and suggests that we find a Marco Polo specialist! Does anyone know of a MB dealership in the south-west of the UK that is used to MPs? The vehicle is still under warranty.
Thanks!
Thanks- we had thought about that but as it’s still under warranty we had hoped that MB would sort it out! I expect that’s what we will have to do. Thanks for you reply!
Hi
Thanks!
I had the same problem. MB Worcester fitted a new sensor. Ok now
My freshwater tank sensor seems to have failed too. I’ll get it sorted and provide an update here for anyone interested.
Hi
Thanks!
Had a similar issue several years ago.
I opened the top of the tank, lifted the level sensor up and down a few times, checked the dashboard indicator, all ok, obviously just needed some TLC and a few kind words
