I am seven months in with my MP and use it most days. I have not experienced any problems with any aspect of my vehicle, everything works just as intended. It's an interesting question to pose, do you have an issue that maybe someone on here can help you with?Has anyone had electrical failures on the leisure side of the vehicle.
A timely question - my leisure battery appears to be flat and not holding a charge. Voltage is up on the display when engine running but drops off quickly when shut off. Think this indicates charger is working but an issue with the battery...
I get that when engine on and charging. However drops to 12.6v when engine switched off and down to 12.5v this morning (although very cold!) Is this normal or is my leisure battery cooked? Presume a MB warranty issue if so?
Interesting - thanks for checking. Also using aux heating almost every day so could be related to this. I also have all charge bars showing. I await your post charge number with interest!
