I have an ongoing fault with the navigation system that Mercedes are trying to fix. I would like to know whether others have a similar problemor whether it is just my vehicle:
After setting in a destination the speech synthesiser responds with “ ‘tis being calculated” instead of “The route is being calculated”
If this were the only fault I would probably put up with it. Indeed it could be quite endearing if the lady had an Irish accent but she doesn’t!
However, the advance instructions get clipped so that for example:
”In half a mile turn right“ becomes a spontaneous “ Turn right”.
If you just happen to be opposite another turning you can be tempted to take it
Could if one or two of you with Command confirm either that you don’t have the problem or that you do and whether it has been fixed.
