Really, does manual really say it must not run dry? I thought it meant must not run dry when using the tap or shower. I drain the tank for winter, as you said, worried about freezing.Are you suppose to keep some water in the fresh water tank, thinking of draining it down but manual says it must not run dry, bit concerned about it freezing.
HI, thanks for that, thought as much but just wanted some back up, think the warning signal is there as you say do not use tap/shower if there is no water.Really, does manual really say it must not run dry? I thought it meant must not run dry when using the tap or shower. I drain the tank for winter, as you said, worried about freezing.
I’ve just emptied my water tanks and removed the 10amp fuse to protect the water pump.Are you suppose to keep some water in the fresh water tank, thinking of draining it down but manual says it must not run dry, bit concerned about it freezing.
