Suspension upgrade
BobbyMillar
Hi all
Anyone upgarded their suspension? Especially interested in upgrading to air suspension - ride difference/who/cost etc. Seems to be companies in Germany who do this but struggling to see many in the UK. Our rear bump stops have taken a hammering last year and either upgraded springs, air bags or a full air suspension kit will be the answer. I have not talked to our local MB dealer yet but I have assumed they will only fit standard set up and therefore no improvement.
Don't intend doing anything with the suspension as is seems OK with the weight we are carrying. Watch out for your alloy's though, we've had two cracked in the past two years. Got them repaired but if we need a new one and ebay can't provide, there £1500 ish each! I think steel wheels now sound a good option.
Hi all
Our MP came with the optional sport suspension (supposedly slightly lower and stiffer) and we were bottoming too frequently. We also had to replace cracked rear bump stops.
We've just replaced our springs with reinforced MAD springs ( https://mad-suspensionsystems.com/en/products/reinforced-main-springs/ ) and the difference is massive. The van no longer seems to float on linked tight turns, and I don't think we've hit our bump stops again.
I had VB Full Air suspension fitted which is great. It has a park setting as well as a sport setting which is great on overseas toll roads. I think my fitting was the first for VB in this country as they originally said it couldn’t be fitted. Talk to Courtside in Devon.
They remove the existing suspension. They will also can give you the existing suspension should you wish to put it back.
Does that mean also removal of the Agility control (to be honest i have no clue what it actually is. I know what they say it does but how it works i do not know) its around 3000 Euro´s installed i got a quote on that. Then the car will get 3-4 cm. higher as well. I am also considering the OEM Air suspension from german manufactor.
Thanks I've contacted them for a quote.
They have quoted £5995 plus VAT. I've also contacted my local MB dealers to see if they will do an upgrade to Airmatic. Then decision time!
My 2016 model is fitted with Billstein B6 suspension and MAD springs… it drives like a car, not a van… it’s flying over the highway. Don’t think I ever want to drive without this upgrade. Former owner did it, he told me he was frustrated that it didn’t come with this as a factory standard..
Is it also raised ?
Hi, can I check whether you replaced the rear shock absorbers at the same time as you replaced the springs.
Also, do you feel that you would have needed to upgrade the front suspension set up at the same?
I've a failed rear spring and 2 worn bumpers so due to get both replaced after Easter. Do you happen to know the part number of the springs you had fitted?
Im interested also in this upgrade with MAD springs & billstein shocks is there a dealer in the UK?
What about the AMG/Agilty control system - can that be dissabled easily?
thanks for any help
thanks for any help
Worth trying these for best option.
MAD direct web shows they also sell Koni rather than B6
Thank Rob and Sandra I’ve now just done Mad springs only on the rear these girls run heavy so a must !! My old ones were giving up and bump stops gone I got mine from a German site specifically for marco polo- 399 euros for x2 plus import tax at 90£ <> very happy transformation ! Thanks ( I’ve got web details if anyone needs )
Evening. I have spoken to MAD in the UK and ordered the recommended upgraded springs. Available in stock part no 098088. @£312..
Sorry, didn't read the forum for some time.
We replaced all four springs (and a worn bumper), but kept the original shock absorbers.
Cannot remember the part number, but you can search by car / model / year at the mad-automotive page. Ours are +2cm if I recall correctly.
