Leisure area lighting
Ian M
Does anyone know how to switch off the ground level lighting under the storage kitchen area as mine is staying on permanently
Is there an isolation switch / fuse for the circuit ?
Anyone know how to solve this ?
Maybe rocker switch failed/stuck. Give it several actions. It’s down by the hookup isolator and power socket behind passenger seat. . Wouldn’t have thought just that light is via a single fuse or relay, but not sure.
Dear Rob
yes tried that switch but that didn't work however i located a brown 7.5 amp fuse in the back by the gas isolation valve that when removed voila the lights were off - not sure what else may be impacted but at least there is no further drain on the Leisure battery
Does this circuit breaker look to be in the off position? Could that have been the issue? Mind you that wouldn’t explain how the power is to the lights in the first place I guess.
