Rear tail light replacement
Schojack
I need to replace a cracked rear tail light on my Marco Polo (part number A4478200664). Seems a simple job to replace - can anyone recommend the best place to purchase a new part that isn't made in China?
Got mine off Ebay - as I cracked mine.
don't get a generic Chinese copy try an OEM item - there are a few genuine ones - I paid £90 for mine and fitted it in 5 minutes. Search on You Tube for instructions but it literally is just 2 screws, slide and pull to remove then exactly the same to put back.
Thanks for that. I've sourced on eBay also and avoided anything from China. Also looked on You Tube and, as you note, looks pretty easy to install.
Received my replacement via eBay (Hella version). Really easy to install as you stated - thanks. I would add that it’s important to get a replacement that works on 12V. The first light I received was for 13.5v and did not function when fitted.
I’m struggling to find the part number for a left hand side (uk model) so passenger side rear tail light for my Marco Polo v250 2019.
There’s a slight crack that allows water and condensation in. I’d like to swap it out. I used the above part number but it doesn’t look the same. The reversing light on mine is rectangular around the whole lamp.
Actually I’m an idiot. Wrong part totally.
However this seems ridiculously expensive.
The premium car brand owners tax! Take the actual cost of purchase from the OEM, double it and then add something on.........
I’ll check with Mercedes for a laugh later - A4478200664.
