Diesel Heater installation - Great job
M
Mark E Smith
ACLS Motorhome & Marine - supplied and installed the Webasto 2kW unit with low noise pump/exhaust
Great job very professional and works a treat.
Well worth the drive up to Dumfries for the day !
dare I ask the price for the unit and installation please Mark
About £1350 all in inc the enhanced more silent fuel pump & exhaust.
One thing to be aware of Tony is that removal of the front passenger seat is required to complete the installation.
In some cases following replacement of the seat, a fault code (Safety Restraint System or something similar cant quite remember) is generated on the vehicle.
This will require a visit to either a main dealer or decent indy with Mercstar software to simply reset this fault code, there will obviously be a cost associated with this task.
Have a chat with the installer they will advise you.
Thank you Mark, much appreciated, I have been reading all the problems people have been having with paint blistering and pop tops being replaced. I will ensure I have a good luck on final acceptance.
When you received your new Mp, did it include charging cable?
Hi - you don't get a charging cable, its a standard hook up you can get on line. Also on the blistering, I've had mine replaced but now its nearly 6 years old I'm not to fussed if it does blister again. You had to look to find it and it doesn't affect the usability or the aesthetics unless you get on a step ladder! I was more concerned originally when I had paid out for a new vehicle and it had faulty paintwork!
We had the roof changed, the blistered appears again on the new roof within 12 months. They are very obvious, pimps about 2/3mm diameter, if you try to polish the roof the tips come off and you are left with a white dot. I think the body work is covered for 7 years. So we will get it redone next year…a pain, but it’s only cosmetic.
Buy a 25m hook up lead some sites hook up points are a fair distance from the pitch.
I too am not that mithered about any roof blisters and have not even checked following my roof replacement about 4 years ago
