awning
jeff porter
Hi anyone advise which best air awning for r/h door marco then pls ideally from online shop but all state left hand door woyld they fit? but presume enterance would be other end?
Hi I have just posted a similar question. Could I ask which one you decided on?
My personal fave is the Kampa Cross Air, but it depends on the size of awning you want and the thickness of the material. Vango make quality awnings, but I found the Galli was way too hot for a 2 week holiday in northern france.
Here's a good article with a focus on the Marco Polo: https://campingsecrets.co.uk/best-drive-away-awning/
And a review/unboxing of the Kampa Cross Air - it's highly modular which makes it very flexible. Also not too expensive!
Thank you this has been really helpfull could you tell me if you have the mid or low version of the kampa cross air for your marco polo. Kind regards. Sarah Jane
After a lot of research and one false start we have just decided on the DWT Picco Air, https://www.nordiskcampingutstyr.no/shop/dwt-bustelt-picco-7479p.html or https://dwt-zelte.de/alle-mobilzelte/nur-mobilzelte/picco-air.html. It seems to be smaller than the Kampa Cross Air which gets good feedback here, but I think it's plenty big enough for our use. Haven't used it in anger yet, just put it up in the lounge to check that it looked OK and that the air tubes didn't leak. Looks good, though like all these tents it takes quite a chunk of luggage space. I think our problem in Norway (for any attached tent) is going to be finding ground which lets us put tent plugs in - Norway is just a big pile of rocks with not much on top! And the problem with the DWT as an answer to this question is that I fear that there is no dealer in UK. But the info might help somebody.
Thank you so much
Last question!!! Could you advise which size connection kit we will need as our van does not arrive until august and we have opted not to have the wind out awning so will need kit to connect to roof . Thank you again for your help.
