Unable to fill water tank
Jonas_80
when filling the water tank from outside the vehicle, are you suppose to open something before? I just get it to spill over, and have filled directly on the tank instead.
it is a 2005. I have seen that the drain pipe is a bit narrow in a bend. Causing it to drain very slow if that could effect this.
Kind regards Jonas
Hi Jonas , did you get a solution for that ? It’s happening the same with our 2011 viano and the only way not to spill is to open the water tank from the inside ..
