Does anyone ever use the through load system?
The description is a bit optimistic. It‘s just a hole beside the seat drawer and anything put through is likely to tangle with the seat cable and possible damage it.
The only time I have removed the cover was to confirm the location of the button to reset the seats in case I ever needed to find it.
It took several attempts to remove the panel. The manual shows the catch mechanism from behind ( you can’ see the catch) so you have to feel for it.
IMO not the best piece of design and a wasted space.
However, if anyone regularly takes off the panel and uses it I would be interested in case I’m missing a trick.
