That's true.... but I prefer the internal option, let's see how it goes.Another advantage of external is it helps to keep the pop top material dry thus helping to reduce damp
				HiI bought this one instead of the Mercedes one from Project Camper. It uses magnets instead of velcro (for the most part) and is very nicely made. Apologies, but only in German however Google Translate is your friend!
ProjectCamper Dachisolierung Modell 447 Marco Polo
Für die Harten unter uns Marco Polo Fahrern ein Muss - beim richtigen Wintercamping geht es nicht ohne - Dank ProjectCamper Dachisolierung hat man auch bei harten Temperaturen ein warmen Innenraum. Maßgeschneiderte Aufstelldach-Isolierung mit magnetischer Befestigung für Mercedes Marco Polo (ab...www.marcopolo-mylife.com
No, you can’t leave it on. But it takes less than 30 seconds to take it down (it’s 4 pieces) and lay it flat on the upper mattress. It’s only about 5-10mm thick and my roof closes fine with it stashed up there ready for the next adventure. Then another 1 minute to put it up in winter.Hi
Thanks for this, it looks like a great alternate to other models requiring to drill holes...it's quite expensive though...I imagine you can't leave it on when closing the roof ?
I also bought the kit for the front windows and absolutely love that. It gets more use when stealth camping. And I store that it a net that I attached to the underside of the upper bed. Easy to grab and install on the front windows with magnets.Hi
Do these panels also protect from the heat ? Have you tried them in hot temperatures, and seen a difference ?I also bought the kit for the front windows and absolutely love that. It gets more use when stealth camping. And I store that it a net that I attached to the underside of the upper bed. Easy to grab and install on the front windows with magnets.
I only received them a few weeks ago so I have not used them in the heat. For the heat I have a Mark 2 Zero Breeze:Do these panels also protect from the heat ? Have you tried them in hot temperatures, and seen a difference ?
					www.zerobreeze.com
