Special gas regulator washer
CT1664
Hi all
I picked up a MP recently and on first use of the gas could smell the dreaded odour of a leek at the bottle connection. Closer inspection proved a simple issue of no rubber washer on the regulator.
is there any experience in the group of where to source a replacement? A standard ‘flat’ washer doesn’t create a seal as there’s a ridge in the connecting housing.
Hoping that’s clear.
Thanks!
Are you talking about the connection between the valve and the bottle, or the valve and the regulator. Either way see below.
https://vwcaliforniaclub.com/shop/product/genuine-gok-gas-hose-seal-kit - this'll get you a regulator seal but it's a kit with the hose etc.
I'm pretty sure it's a 10 x 3.5mm Nitrile O'Ring - fairly common, I think they're the same size as scuba bottle O'Rings - will have to remind myself to check.
The cylinder gasket you should be able to get from your gas bottle stockist, that's 26mm OD x 14mm ID x 1.5mm t.
