mohammedwasim2009@hotmail
Hi everyone,
My Side door is acting up. If I try to open it via the key or center console you can hear it try to open but the door closes up again. If I pull the handle from the outside the automatic function works perfectly fine.
Operating the door via the buttons once open is perfectly fine as long as its not shut. And then back to it not opening unless manually pull on the handle to enable the automatic function.
Hopefully it's a simple fix.
Mohammed
Mohammed
