My Marco Polo (2017 reg, 32K miles) has just failed its MOT on braking efficiency (it is the first time I have taken it through an MOT).
The brake test results were as follows (vehicle weight 3098kg):
What I can't work out is why it has failed? The brakes look in good condition, the disks are clean and pads are a reasonable depth. What else can cause the braking efficiency to be too low? Does anyone else have a copy of their brake test results (in kg as above) which you could post on the forum so I can work out whether its the front or rear brakes on mine causing the problem?
I have had this on my car once before - the discs were a bit rusty, the dealership phoned up to say it had failed (no mention of the discs being rusty) and said needed new discs and pads all round. I drove the car around the block braked hard a few times scrubbing off the rust and it passed the retest. It wasn't until 8 year later I replaced the discs and pads. Consequently I never returned to the dealership.
However the discs on my Marco Polo are shiny, flat, no signs of uneven wear and the pads in good condition. Its on all-weather tyres (newish, 2,800 miles of use) but I presume they wouldn't affect the test? And, it passed its MOT 1 year and 2,800 miles ago with the previous owner with no mention of the brakes. Apart from some hard braking to clean the pads and discs and getting it retested somewhere else I am not sure what to do? Given my previous experience its difficult not to be suspicious. Is the test dependent on how hard the tester pushes the brake pedal? Does anyone have any suggestions? The dealership have said they will need to look at the brakes and it could take than more than a day to fix - without specifying what they might want to fix.
Thanks,
Phil
- Front left: 416 kg (28%)
- Front right: 397 kg (27%)
- Rear left: 440 kg (27%)
- Rear right: 445 kg (27%)
- Total left 856 kg, Total right 842 kg, overall 54%
Thanks,
Phil
