Leisure area lighting
Ian M
Does anyone know how to switch off the ground level lighting under the storage kitchen area as mine is staying on permanently
Is there an isolation switch / fuse for the circuit ?
Anyone know how to solve this ?
Maybe rocker switch failed/stuck. Give it several actions. It’s down by the hookup isolator and power socket behind passenger seat. . Wouldn’t have thought just that light is via a single fuse or relay, but not sure.
Dear Rob
yes tried that switch but that didn't work however i located a brown 7.5 amp fuse in the back by the gas isolation valve that when removed voila the lights were off - not sure what else may be impacted but at least there is no further drain on the Leisure battery
