Grey waters
isabelscosta
Hello, could you please advise the bets product you found to clean the grey waters container from the washbasin ? I'm not going to take it out to clean it but would like to doit every 3/6 months from the washbasin . I think I read this is possible ? Add a product that will go to the grey water and then will come out the I open the valve of they grey waters? It's the first time I'm doing it so any assistance is very much appreciated :) thanks !
Bio laundry powder or sachets dissolved in water and poured down the sink, let it slosh around for a few days then drain.
That's a good suggestion - I've used washing soda in the past which was OK-ish
I use Puriclean powder which is designed to 'clean and purify all stored water systems'.
You dissolve a teaspoon in 5 lts, and tip into water tank then run through tap shower etc for a bit then leave for 12 hours (overnight!) then just run the rest out and flush again with 2 full fillings of water (fast enough if you use the shower outlet in the rear with just a hose attached).
You can catch the run water into the grey tank too where it will do the same job.
It's available on Amazon and from most leisure shops - price varies but around £6 I think for 400g which will last years!
Hope that helps?
