Ad Blue Malfunction and engine light
JEAK
Any one had this isssue.
Ad blue is full.
Light came on and took to local garage - diagnostics said Ad blue and NOX sensor issue. Reset light went out. 50 miles later and message came up and 20 miles later light came on.
Ad tank is full. Local garage says lots of Mercedes have had similar issues and to contact dealer to see if they can resolve as a known fault. Our local dealer is really unhelpful.
Don’t mind travelling to get sorted. We are based in Yorkshire.
Has anyone had any similar issues? Any advise? Anyone had a helpful Mercedes Dealer who have been supportive with a similar issue.
Due to go away soon so really bad timing. Worried I. Case engine stops working whilst we are away.
Not had this or can't recall anyone mentioning it previously. This is just a V-class issue so not sure why a dealer wouldn't help?
I've not had this or seen either. A little googling suggests there are a number of possible causes from NOX sensor failure to the Ad Blue pump or heater failing. It needs a dealer or Merc specialist to diagnose. SteveB is correct this is pure V Class / Vito stuff so not beyond any dealer to diagnose once they have the fault codes read from the vehicle. I think the 485 miles warning means no restart after that distance - but that is hearsay from research.
I’ve had a similar adblue issue. I think it was caused by a loose wire under the driver’s seat. I ended up having to pay Mercedes to fix, circa £500, despite protesting strongly that it was a common fault. Have not and will not use Mercedes dealerships again. Have found a good alternative Mercedes specialist.
I’ve also just had a Adblue Malfunction message,together with engine light. Anyone else has any recent experience in fixing it? Thanks
Not seen this but depending where in Yorkshire you are we recently used Mertrux Huthwaite J28 M1 to resolve a speed sensor issue. Very helpful. Or MBCentre Nottingham always been great for us with several Mercedes vehicles. https://www.mb-centre.co.uk/
Not seen this but depending where in Horkshire you are we recently used Mertrux Huthwaite J28 M1 to resolve a speed sensor issue. Very helpful. Or MBCentre Nottingham always been great for us with several Mercedes vehicles. https://www.mb-centre.co.uk/
thanks, I am in Surrey so will struggle to reach any of them. I got Merceds Roadside Assistance/RAC coming for a look this morning and I hope at least they could give me a fault code reading...
I had the same message come up on my V Class. The Mercedes dealer had to change the NOX sensor. Within a year I had 3 of them changed. It is a fairly common problem and at the time about 3 years ago parts were hard to get. The dealer stated that they had one car there for 3 months waiting for parts. I was lucky as Mercedes loaned me a car I think that they pushed me up the queue.
One thing to note is once the message gets to 0 miles the vehicle will not start. It won’t cut out but the software prevents the next start.
3 years ago I was told the sensor is fairly easy to change but is not carried on the Mercedes Assist Vans as they are too expensive at the time around £800.
