50amp fuse location
anyideas
Hi
Can anyone tell me where the 50a fuse goes that’s been removed on delivery?
The letter says under drivers side seat but I cannot see anywhere for it to go?
I can't believe that your dealer has not fitted it for you! I have not done it myself but I think you need to remove black cover at front of seat base (two screws) you should then see the pre-fuse box. Good luck.
On the drivers seat or passenger seat?
Fuse box under the driver's seat
Designation Consumer Cable colour (cross-section [mm2 ]) Fuse rating
F60/6 Main fuse red/black (6) red (6) 50 A
F60/8 Heating red/purple (4) red (4) 40 A
F60/3 Charging adapter power supply red/yellow (2.5) red (2.5) 25 A
F60/2 Additional battery charge red/blue (2.5) red (2.5) 25 A
F60/5 Central control panel voltage measurement red/orange (0.5) red (0.5) 5 A
Its on the side under the drivers seat. Just pull out the plastic cover. And the place to put the fuse is not documented, but on my MP its on the left side (a free space).
I’ve removed the plastic tray on the side but it doesn’t appear to be there.
I also removed the 2 hex bolts from the metal
Front panel but that won’t budge.
Guess it’s back to the dealers.
Sorry couldn't be of more help, hope it's sorted quickly for you.
Sorry for a late reply but I am in the middle of my first trip away in the MP. The fuse is under the passenger seat in a RHD UK MP . Standing outside the van, the cover below the seat lifts up and away from the seat base.
