Here's the end of the story which I'm sharing to help anybody else who experiences the death of a fridge (compressor) in an older model Marco Polo. The most normal fridge failures are the electronic control unit or the temperature sensor, and in these cases there are modern spare parts which are compatible and can be used as replacements if you have somebody competent to do that. If you are unlucky and the compressor has failed, then basically the unit is dead and must be replaced. That's what happened to us.
The old fridge was made by Dometic for Westfalia, and was very much adapted to the Westfalia conversion. The model is called RC1142. It had an inset in the bottom which allowed the pipes to fit around the wheel arch behind it, and it had control electronics which were adapted to the central console in the front of the van. The RC1142 is of course no longer available. This is what we did to replace it.
First, you have accept that any replacement is going to have to be mounted so that the top is about 10cm above the benchtop. That's because none of the possible replacements have the inset to make space for the wheel arch etc - they are all standard rectangular boxes. We located the three possibilities mentioned previously
- Dometic Coolmatic CB40W
- Vitrifrigo TL43(R)
- Isotherm BI41 Dual
None of these integrate with the MP control unit, they just take 12v in and have their own on/off/thermostat setup. I think any of them would have physically fitted, but we could only find an Isotherm BI41 readily available in Norway. The Dometic seemed almost to be going out of production. The Vitrifrigo seems to insist on a drain for condensation, which doesn't suit the Marco Polo; it also has a separate thermostat unit which would make installation trickier. So we have a new Isotherm BI41 Dual.
First you have to figure out how to remove the old RC1142. Not obviously it comes out forwards, not upwards. I found a brilliant set of instructions written by a Frenchman in 2013,
https://marcopolo.superforum.fr/t5133-tuto-remplacement-frigo-sur-viano-marco-polo. Any decent web browser will translate it for you. I managed that on my own. After that I got our local caravan shop to fit the BI41. They used an IKEA kitchen side panel (FÖRBÄTTRA, dark grey) to build a box above the bench top. The original hinged top came off and the new BI41 isolated top fitted under it; it is no longer hinged, we simply lift the top off to get at the fridge.
All in all, I think it worked well.
