AdBlue Message Reset
SteveB
Hi,
I was prompted by the message below to top up the AdBlue. The tank is now full but the message remains. Does anyone know how to reset the AdBlue Sensor ?
Thanks in anticipation
Steve
I’m only speculating here but there is a factory reset from the main menu on the dash. Might be worth a go. Also when I had issues with an abs sensor fault there is a way of resetting by holding down the brake pedal and turning on the ignition (can’t recall the exact steps). Maybe the manual or some online help can point to this and it’ll help.
Have you filled the adblue such that you can get any more in the tank?
Our Marco is 2017 and we were told the tank only takes 10 l whereas the sensor looks for more, based on an unconverted van.
