I am struggling to remove the auxiliary battery. The procedure set out in the operating manual may be fine for the starter battery but there is not enough length on the positive cable to slide the battery far enough out of the housing to remove the terminal. Nor is there enough room between the battery and the housing to remove the positive cable from its connection on the left hand side of the battery. The MP supplement, as far as I can see, does not give instructions, so any suggestions would be much appreciated Andrew
Apologies if this problem has been covered (or is in the manual!).
