Ladder solution
Paul Merritt
After looking for a long time for a ladder solution and not being drawn to any on the market, particularly the price, I decided to look at a bespoke solution. I purchased an off the shelf telescopic ladder and cut down the width and length to fit in-between the front seats, total cost £39.95 and few hours of my time, perfect.
edzt
Like it, what length did you end up with and why did you narrow it....to store between the seats?
edzt
When you narrowed the rungs did you have to re-cut the slots for the slide buttons or am I missing something
Paul Merritt
I used one of cut of ends as a template, drilled out most of the slot then gently cut the rest with a wood chisel and file.It comes apart very easily just pull out the catches and drill out the pop rivets each end and the side comes of then its just a case of cutting each rung down, reducing the height is a bit more tricky because of the telescopic legs.
edzt
Thank you, awesome job, height doesn’t bother me as I found a 2metre one on Amazon
I better dust my Dremel off
