Hello! Any suggestions! Popped roof up over the weekend, when I put it down, took 2 or 3 goes to get the roof closed symbol to show on the screen. When it eventually did, show closed, had a continuous warning beep, which eventually stops after about a mile, but, comes on again, soon as you stop and restart. Annoying, if not potentially dangerous, as I assume, maybe the roof has not latched properly, although panel says closed. Tried today to investigate, popped top, brought it down several times, now even worse, won’t even register as closed, at all, plus beeping alarm. Not driven far lately, could it be low battery voltage, although I did run the engine to bring voltage up to over 14 before opening. Any ideas?
