I would imagine that they will need to drain and flush the diesel tank. More than likely need to remove it to do so tooWe have inadvertently put some AD Blue, about 1 litre into the diesel tank obviously by mistake, did not start the engine and vehicle is with main dealer now, anyone fully know what they do and likely costs, filled it up with the stuff lots of time so not a complete idiot.
Sorry to hear that Colman, perhaps you can seek a second opinion?...I can imagine this issue happens regularly enough, especially when you consider how many other MB vehicles use the tank/pump/engine combination you have.Thanks for your replies, now for the shock the tech guy at Inchcape in Nottingham. It could be a full replacement of tank, pump and all piping at a cost of 11.5 k, or if we only replace tank pump and some other bits £4.5k, or the cheapest version is around 2.5k, but one repair would result in the warranty being lost on the engine , the car is 18 months old with 25,000 miles, I am stunned that despite car not been started they say because the ignition was turned on to release the steering lock to be loaded on the trailer potentially that has caused the fuel to move, I might be lucky that it has only reached the fuel filter but the tank and fuel will still need replacing hence even the cheapest quote. find it strange that the tank cannot be drained and cleaned, Direct Line do that through Green Flag as part of any claim they get, I know it was my fault but come on Mercdedes
